版主: 51FPGA
分享到:
共1条 1/1 1
FIFOs Using Virtex-II Shift Registers - Obsolete
    [您是本帖的第1405位阅读者]
Rancho
我是GG
高级会员
最后登陆时间:2015-01-14 09:17:39
直达楼层
1# 发表于 2012-05-13 09:13:25
The shift registers available in Virtex®-II devices are ideal when building synchronous FIFOs. By using the flexibility of the shift register LUT primitive (SRL16), FIFOs can be built with any width while producing a 1-bit resolution. With cascaded SRL16 shift registers (SRLC16), a flexible depth in multiples of 16 is available. This document is obsolete/under obsolescence.
xapp256.pdf
关键词:FIFOs    Using    Virtex-II    Shi
Rancho。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
