版主: 51FPGA
分享到:
共1条 1/1 1
Common Switch Interface CSIX-L1 Reference Design - Obsolete
    [您是本帖的第1278位阅读者]
Rancho
我是GG
高级会员
最后登陆时间:2015-01-14 09:17:39
直达楼层
1# 发表于 2012-05-09 18:17:45
This application note describes a Virtex®-II device implementation of a CSIX-L1 common switch interface between a network processor’s traffic manager and the switching fabric for ATM, IP, MPLS, Ethernet, and similar data communications applications. This design uses a pipeline implementation to achieve a low clock period (approximately 166 MHz), and uses the 32-bit interface CSIX scheme. This document is obsolete/under obsolescence.
xapp289.pdf
关键词:Common    Switch    Interface    C
Rancho。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
