版主: 51FPGA
分享到:
共2条 1/1 1
下载问题
    [您是本帖的第3801位阅读者]
bianzhenglan
我是MM
高级会员
最后登陆时间:2012-03-07 16:15:31
直达楼层
1# 发表于 2010-05-13 16:21:15
我用的是ise11.1和xc3s700an,当我在下载到内部flash时,出现“programming fpga only”可以成功下载,但是“program fpga and flash”却不能正确下载不知道为什么,求高手指点啊
具体报错信息如下:
GUI --- Auto connect to cable...
AutoDetecting cable. Please wait.
PROGRESS_START - Starting Operation.
 Cable is LOCKED. Retrying...
Connecting to cable (Usb Port - USB21).
Checking cable driver.
 Driver file xusbdfwu.sys found.
 Driver version: src=1027, dest=1027.
 Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811.
 Cable PID = 0008.
 Max current requested during enumeration is 300 mA.
Type = 0x0005.
 Cable Type = 3, Revision = 0.
 Setting cable speed to 6 MHz.
Cable connection established.
Firmware version = 2401.
File version of D:/Xilinx/11.1/ISE/data/xusb_xp2.hex = 2401.
Firmware hex file version = 2401.
PLD file version = 200Dh.
 PLD version = 200Dh.
PROGRESS_END - End Operation.
Elapsed time =      0 sec.
Attempting to identify devices in the boundary-scan chain configuration...
INFO:iMPACT - Current time: 星期一 四月 27 14:43:06 2009
Identifying chain contents...'0': : Manufacturer's ID = Xilinx xc3s700an, Version : 2
INFO:iMPACT:1777 -
Reading D:/Xilinx/11.1/ISE/spartan3a/data/xc3s700an.bsd...
INFO:iMPACT:501 - '1': Added Device xc3s700an successfully.
done.
Elapsed time =      1 sec.
'1': Loading file 'E:\useful\FPGA\DriverCCD\ccdtmdrv.bit' ...
done.
Found sync word in bitstream.
UserID read from the bitstream file = 0xFFFFFFFF.
INFO:iMPACT - Current time: 星期一 四月 27 14:43:21 2009
Maximum TCK operating frequency for this device chain: 10000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': SPI access core not detected. SPI access core will be downloaded to the device to enable operations.
INFO:iMPACT - Downloading core file D:/Xilinx/11.1/ISE/spartan3a/data/xc3s700an_spi.cor.
'1': Downloading core...
done.
'1': Reading status register contents...
CRC error                                         :         0
IDCODE not validated while writing FDRI           :         0
DCM Locked                                        :         1
status of GTS_CFG_B                               :         1
status of GWE                                     :         1
status of GHIGH                                   :         1
value of VSEL pin 0                               :         1
value of VSEL pin 1                               :         1
value of VSEL pin 2                               :         1
value of MODE pin M0                              :         1
value of MODE pin M1                              :         1
value of MODE pin M2                              :         0
value of CFG_RDY (INIT_B)                         :         1
DONEIN input from Done Pin                        :         1
SYNC word not found                               :         0
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0011 1111 1110 1100
INFO:iMPACT:2492 - '1': Completed downloading core to device.
INFO:iMPACT - '1': Checking done pin....done.
'1': Core downloaded successfully.
INFO:iMPACT - SPI Device not found.
INFO:iMPACT:2488 - The operation did not complete successfully.
'1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and spi mode settings.
Elapsed time =     28 sec.
关键词:下载    问题    iMPACT
RE: 下载问题
bianzhenglan
我是MM
高级会员
2# 发表于 2010-05-14 09:22:02
是啊 当时选用这款也是因为他的内部flash啊
共2条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
