版主: 51FPGA
分享到:
共3条 1/1 1
HDMI输出驱动芯片SIL9022A控制寄存器map找不到
    [您是本帖的第16733位阅读者]
498427664
我是GG
高级会员
最后登陆时间:2015-10-30 18:29:53
直达楼层
1# 发表于 2015-10-30 18:28:13
使用Z turn board时想调用它的HDMI输出视频,但要先对它的驱动芯片SIL9022A初始化,所以就要控制寄存器的列表,然而google都找了也没找到,求教。
Xilinx官方XAPP1205里面调用了HDMI,里面对HDMI进行了初始化,然而没有给出具体寄存器图,我想自己配置。
关键词:Z turn board    HDMI    SIL9022
RE: HDMI输出驱动芯片SIL9022A控制寄存器map找不到
498427664
我是GG
高级会员
2# 发表于 2015-10-30 18:29:10
XAPP1205片段:
ZC702_I2C_CONFIG zc702_hdmi_config[ZC702_HDMI_CONFIG_LEN] =
 {0x41, 0x00, 0x10}, // Power Down Control
      //    R0x41[  6] = PowerDown = 0 (power-up)
 {0xD6, 0x00, 0xC0}, // HPD Control
      //    R0xD6[7:6] = HPD Control = 11 (always high)
    {0x15, 0x00, 0x01}, // Input YCbCr 4:2:2 with separate syncs
    {0x16, 0x00, 0x38}, // Output format 444, Input Color Depth = 8
                        //    R0x16[  7] = Output Video Format = 0 (444)
                        //    R0x16[5:4] = Input Video Color Depth = 11 (8 bits/color)
                        //    R0x16[3:2] = Input Video Style = 10 (style 1)
                        //    R0x16[  1] = DDR Input Edge = 0 (falling edge)
                        //    R0x16[  0] = Output Color Space = 0 (RGB)
    {0x18, 0x00, 0xE7}, // Color Space Conversion
                        //    R0x18[  7] = CSC enable = 1 (CSC enabled)
                        //    R0x18[6:5] = CSC Scaling Factor = 11 (+/- 4.0, -16384 - 16380)
                        //    R0x18[4:0] = CSC coefficient A1[12:8] = 00111
    {0x19, 0x00, 0x34}, //    R0x19[7:0] = CSC coefficient A1[ 7:0] =      00110100
    {0x1A, 0x00, 0x04}, //    R0x1A[  5] = CSC coefficient update
                        //    R0x1A[4:0] = CSC coefficient A2[12:8] = 00100
    {0x1B, 0x00, 0xAD}, //    R0x1B[7:0] = CSC coefficient A2[ 7:0] =      10101101
    {0x1C, 0x00, 0x00}, //    R0x1C[4:0] = CSC coefficient A3[12:8] = 00000
    {0x1D, 0x00, 0x00}, //    R0x1D[7:0] = CSC coefficient A3[ 7:0] =      00000000
    {0x1E, 0x00, 0x1C}, //    R0x1E[4:0] = CSC coefficient A4[12:8] = 11100
    {0x1F, 0x00, 0x1B}, //    R0x1F[7:0] = CSC coefficient A4[ 7:0] =      00011011
    {0x20, 0x00, 0x1D}, //    R0x20[4:0] = CSC coefficient B1[12:8] = 11101
    {0x21, 0x00, 0xDC}, //    R0x21[7:0] = CSC coefficient B1[ 7:0] =      11011100
    {0x22, 0x00, 0x04}, //    R0x22[4:0] = CSC coefficient B2[12:8] = 00100
    {0x23, 0x00, 0xAD}, //    R0x23[7:0] = CSC coefficient B2[ 7:0] =      10101101
    {0x24, 0x00, 0x1F}, //    R0x24[4:0] = CSC coefficient B3[12:8] = 11111
    {0x25, 0x00, 0x24}, //    R0x25[7:0] = CSC coefficient B3[ 7:0] =      00100100
    {0x26, 0x00, 0x01}, //    R0x26[4:0] = CSC coefficient B4[12:8] = 00001
    {0x27, 0x00, 0x35}, //    R0x27[7:0] = CSC coefficient B4[ 7:0] =      00110101
    {0x28, 0x00, 0x00}, //    R0x28[4:0] = CSC coefficient C1[12:8] = 00000
    {0x29, 0x00, 0x00}, //    R0x29[7:0] = CSC coefficient C1[ 7:0] =      00000000
    {0x2A, 0x00, 0x04}, //    R0x2A[4:0] = CSC coefficient C2[12:8] = 00100
    {0x2B, 0x00, 0xAD}, //    R0x2B[7:0] = CSC coefficient C2[ 7:0] =      10101101
    {0x2C, 0x00, 0x08}, //    R0x2C[4:0] = CSC coefficient C3[12:8] = 01000
    {0x2D, 0x00, 0x7C}, //    R0x2D[7:0] = CSC coefficient C3[ 7:0] =      01111100
    {0x2E, 0x00, 0x1B}, //    R0x2E[4:0] = CSC coefficient C4[12:8] = 11011
    {0x2F, 0x00, 0x77}, //    R0x2F[7:0] = CSC coefficient C4[ 7:0] =      01110111
    {0x48, 0x00, 0x08}, // Video Input Justification
                        //    R0x48[8:7] = Video Input Justification = 01 (right justified)
    {0x55, 0x00, 0x00}, // Set RGB in AVinfo Frame
                        //    R0x55[6:5] = Output Format = 00 (RGB)
    {0x56, 0x00, 0x28}, // Aspect Ratio
                        //    R0x56[5:4] = Picture Aspect Ratio = 10 (16:9)
                        //    R0x56[3:0] = Active Format Aspect Ratio = 1000 (Same as Aspect Ratio)
    {0x98, 0x00, 0x03}, // ADI Recommended Write
    {0x9A, 0x00, 0xE0}, // ADI Recommended Write
    {0x9C, 0x00, 0x30}, // PLL Filter R1 Value
    {0x9D, 0x00, 0x61}, // Set clock divide
    {0xA2, 0x00, 0xA4}, // ADI Recommended Write
    {0xA3, 0x00, 0xA4}, // ADI Recommended Write
    {0xAF, 0x00, 0x04}, // HDMI/DVI Modes
                        //    R0xAF[  7] = HDCP Enable = 0 (HDCP disabled)
                        //    R0xAF[  4] = Frame Encryption = 0 (Current frame NOT HDCP encrypted)
                        //    R0xAF[3:2] = 01 (fixed)
                        //    R0xAF[  1] = HDMI/DVI Mode Select = 0 (DVI Mode)
    {0xE0, 0x00, 0xD0}, // Must be set to 0xD0 for proper operation
    {0xF9, 0x00, 0x00}  // Fixed I2C Address (This should be set to a non-conflicting I2C address)
498427664
我是GG
高级会员
3# 发表于 2015-10-30 18:45:22
更正下,好像叫SII9022A
共3条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
