版主: 51FPGA
分享到:
共1条 1/1 1
ISE 14.7 SP601的开发板 CPU RESET管脚为什么会综合出反相器?
    [您是本帖的第5778位阅读者]
a6251356
我是MM
高级会员
最后登陆时间:2015-01-13 22:07:53
直达楼层
1# 发表于 2015-07-25 23:48:31
ISE 14.7  下面代码会在CPU RESET的输入端综合出反相器来,怎么回避这个问题?
module Key_Led_T(
CPU_RESET,USER_CLOCK,
GPIO_LED_0,GPIO_LED_1,GPIO_LED_2,GPIO_LED_3
input CPU_RESET , USER_CLOCK;
output GPIO_LED_0,GPIO_LED_1,GPIO_LED_2,GPIO_LED_3;
//--------------------------------------------------------------------------------------------1
(* KEEP ="TRUE" *) wire rst_n;
IBUF #(
.IOSTANDARD("DEFAULT") // Specify the input I/O standard
)IBUF_rst_n(
.O(rst_n),                                  // Buffer output
.I(CPU_RESET)                      // Buffer input (connect directly to top-level port)
//--------------------------------------------------------------------------------------------2
wire clk_27;
IBUF #(
)IBUF_clk_27 (
.O(clk_27),                                // Buffer output
.I(USER_CLOCK)                   // Buffer input (connect directly to top-level port)
parameter CLK_FREQUENCY1 = 27000000;
reg[23:0] cnt0;
reg cnt0_1s;
always@(posedge clk_27 or negedge rst_n)begin
    if(!rst_n)begin
        cnt0 <= 0;
        cnt0_1s <= 0;
    end
    else if(cnt0 == (CLK_FREQUENCY1/2) - 1)begin
        cnt0 <= 0;
        cnt0_1s <= ~cnt0_1s;
    end
    else begin
        cnt0 <= cnt0 + 1;
    end
end
assign GPIO_LED_0 = cnt0_1s;
assign GPIO_LED_1 = ~cnt0_1s;
assign GPIO_LED_2 = cnt0_1s;
assign GPIO_LED_3 = ~cnt0_1s;
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
