版主: 51FPGA
分享到:
共1条 1/1 1
关于在ISE14.4中调用modelsim6.5进行功能仿真的问题
    [您是本帖的第899位阅读者]
SCOFEEL
我是MM
高级会员
最后登陆时间:2015-01-13 22:10:09
直达楼层
1# 发表于 2015-04-11 22:05:29
modelsim6.5在打开运行时出现下面错误,无法继续进行,求大侠指教一二,谢谢!
Top level modules:
# glbl
# vsim -L xilinxcorelib_ver -L unisims_ver -L unimacro_ver -lib work -voptargs=\"+acc\" -t 1ps work.top_tb glbl
# ** Note: (vsim-3812) Design is being optimized...
# ** Error: DCM0.v(95): Module 'DCM_SP' is not defined.
# ** Error: DCM0.v(120): Module 'DCM_SP' is not defined.
# ** Error: DCM0.v(122): Module 'BUFG' is not defined.
# ** Error: DCM0.v(124): Module 'IBUFG' is not defined.
# ** Error: DCM0.v(126): Module 'BUFG' is not defined.
# ** Error: DCM0.v(128): Module 'INV' is not defined.
# ** Error: DCM0.v(130): Module 'BUFG' is not defined.
# ** Error: DCM0.v(132): Module 'BUFG' is not defined.
# ** Error: DCM0.v(134): Module 'BUFG' is not defined.
# ** Error: DCM0.v(138): Module 'FDS' is not defined.
# ** Error: DCM0.v(141): Module 'FD' is not defined.
# ** Error: DCM0.v(144): Module 'FD' is not defined.
# ** Error: DCM0.v(147): Module 'FD' is not defined.
# ** Error: DCM0.v(150): Module 'OR2' is not defined.
# ** Error: DCM0.v(154): Module 'OR3' is not defined.
# ** Error: tx_fifo0.v(182): Module 'FIFO_GENERATOR_V4_4' is not defined.
# Optimization failed
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./top_tb.fdo PAUSED at line 33
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
