版主: 51FPGA
分享到:
共1条 1/1 1
利用数控阻抗:信号完整性和功耗的考虑
    [您是本帖的第1424位阅读者]
Rancho
我是GG
高级会员
最后登陆时间:2015-01-14 09:17:39
直达楼层
1# 发表于 2012-06-19 11:13:21
On-die termination (ODT) promises higher signaling rates for printed circuit board (PCB) inter-chip interfaces through improved signal integrity. However, when using ODT, there is sometimes an associated power penalty. This application note explains the reason for the power penalty and suggests a simulation technique for comparing the signal integrity and power dissipation of internally and externally terminated versions of an interface.
xapp863.pdf
关键词:利用    数控    阻抗    信号    完整性    功耗    考虑
Rancho。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
