版主: 51FPGA
分享到:
共1条 1/1 1
在Spartan3E/ 3 fpga7:1序列化中速度高达666 Mbps
    [您是本帖的第1156位阅读者]
Rancho
我是GG
高级会员
最后登陆时间:2015-01-14 09:17:39
直达楼层
1# 发表于 2012-06-19 09:26:08
This application note targets Spartan™-3E devices in applications that require 4-bit or 5-bit transmit data bus widths and operate at rates up to 666 Mbps per line with a forwarded clock at 1/7th the bit rate. This type of interface is commonly used in flat panel displays and automotive applications.
xapp486.pdf
关键词:Spartan3E    fpga7    序列化    速度    高达
Rancho。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
