版主: 51FPGA
分享到:
共1条 1/1 1
Verilog中调用用VHDL模块,VHDL端口含有二维数组,Verilog怎么定义
    [您是本帖的第9632位阅读者]
gulong123
我是GG
高级会员
最后登陆时间:2018-08-11 10:02:00
直达楼层
1# 发表于 2019-12-12 20:30:54
最近在工程中,需要用Verilog对VHDL模块进行仿真,VHDL端口中含有二维数组,在Verilog中怎么例化
VHDL模块声明:
entity dma_mod is
generic(RX_NUM :integer:=2);
port (
    activing: in  std_logic_vector((RX_NUM-1) downto 0);
    clk_80m : in  std_logic;
    dma_len : in  ARRAY16((RX_NUM-1) downto 0);  --2X16
    rd_jump : in  ARRAY10((RX_NUM-1) downto 0);
    rd_addr : out std_logic_vector(9 downto 0);
    rd_data : in  ARRAY17((RX_NUM-1) downto 0);
    pcie_clk: in  std_logic;
    iec2dma : out std_logic_vector(46 downto 0);
    dma2iec : in  std_logic_vector(2 downto 0);
    dma_ok  : out std_logic_vector(15 downto 0);
    dma_all : out std_logic_vector(15 downto 0);
    dma_fail: out std_logic_vector(15 downto 0);
    dma_rst : out std_logic_vector(15 downto 0);
    err_num : out std_logic_vector(3 downto 0)
end dma_mod;
wire [15:0] dma_len [1:0] ;
wire [9 :0] rd_jump [1:0] ;
wire [9 :0] rd_addr ;
wire [16:0] rd_data [1:0] ;
dma_mod u1(
    .activing          (2'b11                    ) ,
    .clk_80m         (clk                    ) ,
    .dma_len         (dma_len               ) ,
    .rd_jump         (rd_jump               ) ,
    .rd_addr         (rd_addr               ) ,
    .rd_data         (rd_data               ) ,
    .pcie_clk        (clk                    ) ,
    .iec2dma         (                        ) ,
    .dma2iec         (                        ) ,
    .dma_ok          (                        ) ,
    .dma_all         (                           ) ,
    .dma_fail        (                        ) ,
    .dma_rst         (                        ) ,
    .err_num         (                        )
assign dma_len[0] = 16'h000A ;
assign dma_len[1] = 16'h000A ;
assign rd_jump[1] = 10'h000   ;
assign rd_data[1] = 17'h00000 ;
仿真会报错 ERROR: [VRFC 10-394] cannot access memory dma_len directly ,
怎么解决这个问题? help
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
