版主: 51FPGA
分享到:
共2条 1/1 1
综合告警信息 -- WARNING:Xst:3002
    [您是本帖的第2010位阅读者]
ponyhk
性别保密
普通会员
最后登陆时间:2018-08-17 20:18:49
直达楼层
1# 发表于 2019-04-06 16:18:57
WARNING:Xst:3002 - This design contains one or more registers/latches that are directly
   incompatible with the Spartan6 architecture. The two primary causes of this is
   either a register or latch described with both an asynchronous set and
   asynchronous reset, or a register or latch described with an asynchronous
   set or reset which however has an initialization value of the opposite
   polarity (i.e. asynchronous reset with an initialization value of 1).
While this circuit can be built, it creates a sub-optimal implementation
in terms of area, power and performance. For a more optimal implementation
Xilinx highly recommends one of the following:
1) Remove either the set or reset from all registers and latches
if not needed for required functionality
2) Modify the code in order to produce a synchronous set
and/or reset (both is preferred)
3) Ensure all registers have the same initialization value as the
described asynchronous set or reset polarity
4) Use the -async_to_sync option to transform the asynchronous
set/reset to synchronous operation
(timing simulation highly recommended when using this option)
没有提示是代码什么地方,请问如何解决?
关键词:WARNING:Xst:3002
RE: 综合告警信息 -- WARNING:Xst:3002
ponyhk
性别保密
普通会员
2# 发表于 2019-04-06 16:34:54
ponyhk的原帖
没有提示是代码什么地方,请问如何解决?
问题解决。
告警原因是:
1、寄存器或信号量(总之需要锁存的)有个初始值;
2、在复位电路汇中,又赋予了和定义时候不同的值;
就会导致告警。
比如:
signal power_on    : std_logic := '0';
if (RST_IN = '0') then
    power_on  <= '1';            -- 告警
else
end if;
共2条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
