版主: 51FPGA
分享到:
共1条 1/1 1
when i run the routing, the Vivado can not finish
    [您是本帖的第1890位阅读者]
youguhantan
我是GG
高级会员
最后登陆时间:2017-07-04 11:01:03
直达楼层
1# 发表于 2017-07-04 10:58:26
My vivado is 2017.1
PC: i7, 32GRAM,260G SSD @ win7
when i run the routing, the Vivado can not finish.
It report:
Phase 3 Initial Routing
Abnormal program termination (EXCEPTION_ACCESS_VIOLATION)
Please check 'F:/prj_dprx_zcu102_clk24m_led_3_3/prj_dprx_zcu102_clk24m_led_3/prj_dprx_zcu102_clk24m_led_2/prj_dptx_zcu102_test.runs/impl_3/hs_err_pid6112.log' for details
when i check the pid6112.log. it let me check the dmp file.
the DMP file is below:
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [F:\prj_dprx_zcu102_clk24m_led_3_3\prj_dprx_zcu102_clk24m_led_3\prj_dprx_zcu102_clk24m_led_2\prj_dptx_zcu102_test.runs\impl_3\hs_err_pid4408.dmp]
User Mini Dump File: Only registers, stack and portions of memory are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path.           *
* Use .symfix to have the debugger choose a symbol path.                   *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
Windows 7 Version 7601 (Service Pack 1) MP (8 procs) Free x64
Product: WinNt, suite: SingleUserTS
Machine Name:
Debug session time: Mon Jul  3 14:19:23.000 2017 (GMT+8)
System Uptime: not available
Process Uptime: 0 days 0:14:20.000
This dump file has an exception of interest stored in it.
The stored exception information can be accessed via .ecxr.
(1138.1090): Access violation - code c0000005 (first/second chance not available)
Unable to load image C:\Windows\System32\ntdll.dll, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntdll.dll
*** ERROR: Module load completed but symbols could not be loaded for ntdll.dll
ntdll+0x51fea:
00000000`76dd1fea c3              ret
how can i fix it ???
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
