版主: 51FPGA
分享到:
共2条 1/1 1
petalinux-build错误
    [您是本帖的第1969位阅读者]
铁杜不铁
我是GG
高级会员
最后登陆时间:2015-04-27 18:45:07
直达楼层
1# 发表于 2015-04-27 18:46:57
我在使用petalinux-build时产生下列错误
[INFO ] build system.dtb
[INFO ] build linux/kernel
[INFO ] update linux/u-boot source
[INFO ] generate linux/u-boot configuration files
[INFO ] build linux/u-boot
[INFO ] Setting up stage config
[INFO ] Setting up rootfs config
[INFO ] Updating for armv7a-vfp-neon
[INFO ] Updating package manager
[INFO ] Expanding stagefs
[ERROR] Errors were encountered while processing:
[ERROR] E: Sub-process /share/petalinux-v2014.2-final/tools/packagemanager/bin/dpkg returned an error code (1)
[ERROR] make[2]: *** [.pkg_stagefs] Error 255
[ERROR] make[1]: *** [sub_build_component_/none/packages-repo/single/plnx-repo] Error 2
ERROR: Failed to build linux
不知道有没有人知道错在哪的
RE: petalinux-build错误
nakey
我是MM
高级会员
最后登陆时间:2015-03-02 15:07:30
2# 发表于 2015-04-30 17:53:30
同帮忙问
共2条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
