版主: 51FPGA
分享到:
共1条 1/1 1
MapLib:979 - LUT6 symbol microblaze FSL
    [您是本帖的第1491位阅读者]
091217272
我是MM
高级会员
最后登陆时间:2015-01-13 22:12:51
直达楼层
1# 发表于 2015-04-09 21:25:58
ISE 14.5,在ISE中添加microblaze,在EDK中使用两条FSL连接microblaze和自定义的IP核,edk中生成网表成功,但是在ISE中Map失败,错误如下:
ERROR:MapLib:979 - LUT6 symbol
"embed_cpu_i/fsl_v20_0/fsl_v20_0/Using_FIFO.Sync_FIFO_Gen.Use_Control.Sync_FI
FO_I1/FSL_Flag_Handle.Rd_Delay_For_Bram.fall_through_data_0_dpot" (output
signal=embed_cpu_i/fsl_v20_0/fsl_v20_0/Using_FIFO.Sync_FIFO_Gen.Use_Control.S
ync_FIFO_I1/FSL_Flag_Handle.Rd_Delay_For_Bram.fall_through_data_0_dpot) has
input signal "embed_cpu_i/fsl_v20_0_FSL_M_Control" which will be trimmed. See
Section 5 of the Map Report File for details about why the input signal will
become undriven.
ERROR:MapLib:978 - LUT6 symbol
an equation that uses input pin I5, which no longer has a connected signal.
Please ensure that all the pins used in the equation for this LUT have
signals that are not trimmed (see Section 5 of the Map Report File for
details on which signals were trimmed).
求解决办法,谢谢!
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
