版主: 51FPGA
分享到:
共1条 1/1 1
[Spartan-3] 请教关于3段式状态机的问题
    [您是本帖的第783位阅读者]
xilinx论坛
我是MM
高级会员
最后登陆时间:2015-03-19 10:58:07
直达楼层
1# 发表于 2015-03-31 21:12:55
关于3段式状态机的问题,请各位大虾指教:
代码:
reg [1:0] state_now=2'b00;  //
表示系统当前状态
reg [1:0] state_next=2'b00;  //
表示系统下一个状态
parameter
        Wait = 2'b00,  //
等待状态
       Send = 2'b01; //
产生发送
always @(posedge clk or posedge rst) begin
      if(rst) begin
              state_now <= Wait;
      end
      else begin
            state_now <= state_next;
      end
end
always @(state_now or start or type) begin
       case(state_now)
              Wait:
                 if(start) begin
                        state_next = Send;
                        case(type)
                             2'b00: duty<=1;
                             2'b01: duty<=5;
                             2'b10: duty<=9;
                            2'b11: duty<=0;
                         endcase
               end
           Send:
                 if(!start) begin
                       state_next = Wait;
                       duty<=0;
                 end
           endcase
      end
        if(rst)
             dout <= 1'b0;
        else
        case(state_next)
              Wait:;
              Send:;
              default
        endcase
end
为什么编译后总是有warning
WARNING:Xst:737 - Found 2-bit latch for signal <state_next>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:2677 - Node <state_next_0> of sequential type is unconnected in block <rintHclk>.
WARNING:Xst:2677 - Node <state_next_1> of sequential type is unconnected in block <rintHclk>.
WARNING:Xst:2677 - Node <state_now_1> of sequential type is unconnected in block <rintHclk>.
WARNING:Xst:2677 - Node <state_now_0> of sequential type is unconnected in block <rintHclk>.
请高人指点!
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
