版主: 51FPGA
分享到:
共1条 1/1 1
麻烦帮我看看我这个DMA传输是什么问题呢,传的数据不对
    [您是本帖的第986位阅读者]
jianwenchang
我是GG
高级会员
最后登陆时间:2014-11-18 09:57:05
直达楼层
   resource_size_t dma_tx_chan;
        struct resource *r;
        dma_cap_mask_t mask;
        struct dma_chan         *dma_tx;
        int ret;
        struct scatterlist sg_tx;
        //struct dma_async_tx_descriptor *txdesc;
        struct device *tx_dev;
        u32 tx_vir, tx_phy;
        char *sour;
        //char *dest;
        dma_addr_t dma_dest,dma_src;
        int i;
        struct completion cmp;
        u32 test_size = 1024*1024*4u;
        int rc = 0;
        printk("step 1\n");
        r = platform_get_resource(ofdev, IORESOURCE_DMA, 0);
        printk("step 2\n");
        if (r)
                dma_tx_chan = r->start;
        else
                printk("get dma resource faild\n");
        dma_cap_zero(mask);
        dma_cap_set(DMA_SLAVE, mask);
        dma_tx = dma_request_channel(mask, NULL, NULL);
        //dma_tx = dma_request_channel(mask, edma_filter_fn, dma_tx_chan);
        printk("step 3\n");
        if (!dma_tx) {
                printk("request DMA channel failed\n");
                ret = -ENODEV;
                return ret;
        //allocate a DMA buffer for the transfer
        tx_dev = dma_tx->device->dev;
        tx_vir = kzalloc(8, GFP_KERNEL);
        sour = kzalloc(sizeof(u8) * test_size, GFP_KERNEL);
        if (!sour)
                return -ENOMEM;
        dest = kzalloc(sizeof(u8) * test_size, GFP_KERNEL);
        if (!dest)
                return -ENOMEM;
        for (i = 0; i < test_size; i++)
                sour[i] = (u8)i;
        dma_src = dma_map_single(tx_dev,sour,test_size,DMA_TO_DEVICE);
        dma_dest = dma_map_single(tx_dev,dest,test_size,DMA_FROM_DEVICE);
        struct dma_slave_config dma_tx_conf = {
                .direction = DMA_MEM_TO_MEM,
                .src_addr = dma_src,
                .dst_addr = dma_dest,
                .dst_addr_width = 1,
                .src_addr_width = 1,
                .dst_maxburst = 1,
                .src_maxburst = 1,
        dmaengine_slave_config(dma_tx, &dma_tx_conf);
        sg_init_table(&sg_tx, 1);
        sg_dma_address(&sg_tx) = dma_src;
        sg_dma_address(&sg_tx) = dma_dest;
        sg_dma_len(&sg_tx) = test_size;
        txdesc =  dmaengine_prep_slave_sg(dma_tx, &sg_tx, 1, DMA_MEM_TO_MEM,
                                  DMA_PREP_INTERRUPT | DMA_CTRL_ACK);
        init_completion(&cmp);
        txdesc->callback = dma_tx_callback;
        txdesc->callback_param = &cmp;
        dmaengine_submit(txdesc);
        dma_async_issue_pending(dma_tx);
按照我的思路,应该是从0,1,2.。。。。。。,但实际传的是一些随机数据
在这里往源地址里赋的值
最终通过DMA传到目的地址,如果对的话,数据应该是一样的,但现在是一些随机数据
【村长】北京-某人
你用的什么DMA
【村长】北京-jianwenchang
PS的
【村长】北京-某人
这个我记得xilinx有例程,你可以照着做,就在wiki上
【村长】北京-jianwenchang
wiki上那个不能用,内核太老了,很多头文件都没有了,我还特意问了问写那驱动的外国人
他说不能用了
求大神高见....
友好交流,资源共享。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
