版主: 51FPGA
分享到:
共2条 1/1 1
求大神帮助microblaze在SDK编译时提示cannot find -l-Wl,--start-group,-lxil,-lgcc,-lc,--end-gr
    [您是本帖的第2258位阅读者]
yanhongen
我是GG
高级会员
最后登陆时间:2015-01-19 09:16:28
直达楼层
1# 发表于 2014-09-19 11:07:52
make all
'Building target: EthernetConfig_CAVIAR.elf'
'Invoking: MicroBlaze gcc linker'
mb-gcc -L../../standalone_bsp_0/microblaze_0/lib -Wl,-T -Wl,../src/lscript.ld -mlittle-endian -mxl-barrel-shift -mxl-pattern-compare -mno-xl-soft-div -mcpu=v8.50.c -mno-xl-soft-mul -mxl-multiply-high -mhard-float -mxl-float-convert -mxl-float-sqrt -Wl,--no-relax -Wl,--gc-sections -o "EthernetConfig_CAVIAR.elf"  ./src/lwip-1.4.0/src/netif/etharp.o ./src/lwip-1.4.0/src/netif/ethernetif.o  ./src/lwip-1.4.0/src/core/snmp/asn1_dec.o ./src/lwip-1.4.0/src/core/snmp/asn1_enc.o ./src/lwip-1.4.0/src/core/snmp/mib2.o ./src/lwip-1.4.0/src/core/snmp/mib_structs.o ./src/lwip-1.4.0/src/core/snmp/msg_in.o ./src/lwip-1.4.0/src/core/snmp/msg_out.o  ./src/lwip-1.4.0/src/core/ipv4/autoip.o ./src/lwip-1.4.0/src/core/ipv4/icmp.o ./src/lwip-1.4.0/src/core/ipv4/igmp.o ./src/lwip-1.4.0/src/core/ipv4/inet.o ./src/lwip-1.4.0/src/core/ipv4/inet_chksum.o ./src/lwip-1.4.0/src/core/ipv4/ip.o ./src/lwip-1.4.0/src/core/ipv4/ip_addr.o ./src/lwip-1.4.0/src/core/ipv4/ip_frag.o  ./src/lwip-1.4.0/src/core/def.o ./src/lwip-1.4.0/src/core/dhcp.o ./src/lwip-1.4.0/src/core/dns.o ./src/lwip-1.4.0/src/core/init.o ./src/lwip-1.4.0/src/core/mem.o ./src/lwip-1.4.0/src/core/memp.o ./src/lwip-1.4.0/src/core/netif.o ./src/lwip-1.4.0/src/core/pbuf.o ./src/lwip-1.4.0/src/core/raw.o ./src/lwip-1.4.0/src/core/stats.o ./src/lwip-1.4.0/src/core/sys.o ./src/lwip-1.4.0/src/core/tcp.o ./src/lwip-1.4.0/src/core/tcp_in.o ./src/lwip-1.4.0/src/core/tcp_out.o ./src/lwip-1.4.0/src/core/timers.o ./src/lwip-1.4.0/src/core/udp.o  ./src/lwip-1.4.0/src/api/api_lib.o ./src/lwip-1.4.0/src/api/api_msg.o ./src/lwip-1.4.0/src/api/err.o ./src/lwip-1.4.0/src/api/netbuf.o ./src/lwip-1.4.0/src/api/netdb.o ./src/lwip-1.4.0/src/api/netifapi.o ./src/lwip-1.4.0/src/api/sockets.o ./src/lwip-1.4.0/src/api/tcpip.o  ./src/contrib/ports/xilinx/netif/xadapter.o ./src/contrib/ports/xilinx/netif/xaxiemacif.o ./src/contrib/ports/xilinx/netif/xaxiemacif_fifo.o ./src/contrib/ports/xilinx/netif/xaxiemacif_hw.o ./src/contrib/ports/xilinx/netif/xaxiemacif_physpeed.o ./src/contrib/ports/xilinx/netif/xpqueue.o ./src/contrib/ports/xilinx/netif/xtopology_g.o  ./src/contrib/ports/xilinx/sys_arch.o ./src/contrib/ports/xilinx/sys_arch_raw.o  ./src/main.o ./src/platform.o ./src/platform_mb.o ./src/spiFlash.o   -l-Wl,--start-group,-lxil,-lgcc,-lc,--end-group
c:/xilinx/14.7/ise_ds/edk/gnu/microblaze/nt/bin/../lib/gcc/microblaze-xilinx-elf/4.6.4/../../../../microblaze-xilinx-elf/bin/ld.exe: cannot find -l-Wl,--start-group,-lxil,-lgcc,-lc,--end-group
collect2: ld returned 1 exit status
make: *** [EthernetConfig_CAVIAR.elf] error 1
关键词:microblaze        cannot    -l-Wl
RE: 求大神帮助microblaze在SDK编译时提示cannot find -l-Wl,--start-group,-lxil,-lgcc,-lc,--en
jackwang
我是GG
管理员
最后登陆时间:2015-01-29 08:45:11
2# 发表于 2014-09-19 13:45:03
这是什么东东,怎么会这样子
EEPW高校联络官群:327349274。
共2条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
