版主: 51FPGA
分享到:
共1条 1/1 1
我现在从SD卡启动出现无法识别内核的格式的错误
    [您是本帖的第901位阅读者]
simonmao8385
我是GG
高级会员
最后登陆时间:2014-12-08 13:00:36
直达楼层
1# 发表于 2014-07-01 15:36:47
Device: zynq_sdhci
Manufacturer ID: 41
OEM: 3432
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 3.6 GiB
Bus Width: 4-bit
reading uEnv.txt
** Unable to read file uEnv.txt **
Copying Linux from SD to RAM...
reading uImage
3726976 bytes read in 333 ms (10.7 MiB/s)
reading devicetree.dtb
5309 bytes read in 15 ms (344.7 KiB/s)
reading uramdisk.image.gz
99702893 bytes read in 8450 ms (11.3 MiB/s)
Wrong Image Format for bootm command
ERROR: can't get kernel image!
我是按照wiki上编出来的uImage
我是microzed的板
复制去Google翻译翻译结果
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
