版主: 51FPGA
分享到:
共1条 1/1 1
Parameterizable LocalLink FIFO - Not Recommended for New Designs
    [您是本帖的第1210位阅读者]
Rancho
我是GG
高级会员
最后登陆时间:2015-01-14 09:17:39
直达楼层
1# 发表于 2012-05-13 09:15:47
This application note describes the implementation of a parameterizable LocalLink FIFO, which is a First-In-First-Out memory queue with LocalLink interfaces on both sides. The LocalLink interface defines a set of protocol-agnostic signals that allows transmission of packet-oriented data, and enables a set of features such as flow control and transfer data of arbitrary length. The LocalLink FIFO consists of two LocalLink interfaces, one on the write port to interface with an upstream user application, the other on the read port to interface with a downstream user application. This product is not recommended for new designs.
xapp691.pdf
关键词:Parameterizable    LocalLink
Rancho。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
