版主: 51FPGA
分享到:
共1条 1/1 1
Self-Addressing FIFO
    [您是本帖的第1300位阅读者]
Rancho
我是GG
高级会员
最后登陆时间:2015-01-14 09:17:39
直达楼层
1# 发表于 2012-05-13 09:14:58
The block memories in the Virtex®-II architecture are capable of supporting data bus widths of up to 36-bits. A self-addressing FIFO reference design uses these block memories to store both data and address information in a single memory location. This application note describes FIFO designs where no external counters are required. Only flag and status information logic is used. The resulting FIFOs are not fast (around 150 MHz). Their advantage is in using only one clock load. In addition, the status mechanism is very simple making FIFOs are more suitable for data throttling in continuous data systems instead of the full or empty detection required in frame-based data systems.
xapp291.pdf
关键词:Self-Addressing
Rancho。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
