版主: 51FPGA
分享到:
共1条 1/1 1
170 MHz FIFOs Using the Virtex Block SelectRAM+ Feature - Obsolete
    [您是本帖的第1179位阅读者]
Rancho
我是GG
高级会员
最后登陆时间:2015-01-14 09:17:39
直达楼层
1# 发表于 2012-05-13 09:11:45
The Virtex® FPGA series provides dedicated on-chip blocks of 4096 bit dual-port synchronous RAM, which are ideal for use in FIFO applications. This application note describes a way to create a common-clock (synchronous) version and an independent-clock (asynchronous) version of a 511 x 8 FIFO, with the depth and width being adjustable within the Verilog or VHDL code. A hand-placed version of the design runs at 170 MHz in the -6 speed grade. This document is obsolete/under obsolescence.
xapp131.pdf
关键词:FIFOs    Using    Virtex    Block
Rancho。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
