版主: 51FPGA
分享到:
共1条 1/1 1
A 3/4/5/6X Oversampling Circuit for 200 Mb/s to 1000 Mb/s Serial Interfaces(
    [您是本帖的第1053位阅读者]
Rancho
我是GG
高级会员
最后登陆时间:2015-01-14 09:17:39
直达楼层
1# 发表于 2012-05-13 08:58:08
The oversampling module described in this application note performs 3/4/5/6X oversampling. The oversampling ratio is selectable during operation to facilitate multi-rate applications. It is designed to accept 20 bits of oversampled data and to output 10 bits of extracted data to the user interface. This module can be used with the Virtex-II Pro™ RocketIO™ Multi-Gigabit Transceiver (MGT) to achieve line rates of 200 Mb/s to 1000 Mb/s.
xapp572.pdf
关键词:Oversampling    Circuit    Seri
Rancho。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
