版主: 51FPGA
分享到:
共1条 1/1 1
Indirect Programming of BPI PROMs with Virtex-5 FPGAs
    [您是本帖的第1297位阅读者]
Rancho
我是GG
高级会员
最后登陆时间:2015-01-14 09:17:39
直达楼层
1# 发表于 2012-05-11 18:55:20
This application note describes how to indirectly program select BPI PROMs through the JTAG interface of a Virtex®-5 FPGA using iMPACT. The required hardware setup, BPI-UP PROM file generation, and the indirect programming flow are described.
xapp973.pdf
关键词:Indirect    Programming    PROM
Rancho。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
