版主: 51FPGA
分享到:
共1条 1/1 1
1:7 Deserialization in Spartan-3E/3A FPGAs at Speeds Up to 666 Mbps
    [您是本帖的第1129位阅读者]
Rancho
我是GG
高级会员
最后登陆时间:2015-01-14 09:17:39
直达楼层
1# 发表于 2012-05-09 19:54:43
This application note targets Spartan®-3E/3A devices in applications that require 4-bit or 5-bit receive data bus widths and operate at rates up to 666 Mbps per line with a clock at 1/7th the bit rate. This type of interface is commonly used in flat panel displays and automotive applications.
xapp485.pdf
关键词:Deserialization    Spartan-3
Rancho。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
