版主: 51FPGA
分享到:
共1条 1/1 1
Dynamically Programmable DRU for High-Speed Serial I/O
    [您是本帖的第32168位阅读者]
Rancho
我是GG
高级会员
最后登陆时间:2015-01-14 09:17:39
直达楼层
1# 发表于 2012-05-09 18:41:20
The non-integer data recovery unit (NI-DRU) presented in this application note is specifically designed for RocketIO™ GTP and GTX transceivers in Virtex®-5 LXT, SXT, TXT, and FXT platforms and consists of look-up tables (LUTs) and flip-flops. The NI-DRU extends the lower data rate limit to 0 Mb/s and the upper limit to 1,250 Mb/s, making embedded high-speed transceivers the ideal solution for true multi-rate serial interfaces.
xapp875.pdf
关键词:Dynamically    Programmable
Rancho。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
