版主: 51FPGA
分享到:
共1条 1/1 1
Using the RGMII to Interface with the Gigabit Ethernet MAC - Not Recommended for
    [您是本帖的第1476位阅读者]
Rancho
我是GG
高级会员
最后登陆时间:2015-01-14 09:17:39
直达楼层
1# 发表于 2012-05-09 18:28:45
The Reduced Gigabit Media Independent Interface (RGMII) is an alternative to the Gigabit Media Independent Interface (GMII). In this application note, an RGMII adaptation module is used to reduce the number of pins required to connect the Gigabit Ethernet MAC to a Gigabit PHY from 24 to 12. This product is not recommended for new designs.
xapp692.pdf
关键词:Using    RGMII    Interface    Gig
Rancho。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
