版主: 51FPGA
分享到:
共1条 1/1 1
TCP/IP on Virtex-II Pro Devices Using lwIP - Not Recommended for New Designs
    [您是本帖的第1342位阅读者]
Rancho
我是GG
高级会员
最后登陆时间:2015-01-14 09:17:39
直达楼层
1# 发表于 2012-05-09 18:27:52
P/IP is a communication protocol stack designed to provide a reliable data stream between two hosts. It is a popular means of communicating data over a network. Most people use the protocol every day to check email, browse the web, instant message, and download files. TCP/IP is also becoming more utilized in embedded systems. This application note explores the use of an open source TCP/IP stack on the Virtex-II™ Pro PowerPC™ processor. An example reference design is provided allowing remote interaction with the peripherals on the Insight/Memec designed Virtex-II Pro development board. This product is not recommended for new designs.
xapp655.pdf
关键词:Virtex-II    Devices    Using    R
Rancho。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
