版主: 51FPGA
分享到:
共1条 1/1 1
Using a Microprocessor to Configure Xilinx FPGAs via Slave Serial or SelectMAP M
    [您是本帖的第1332位阅读者]
Rancho
我是GG
高级会员
最后登陆时间:2015-01-14 09:17:39
直达楼层
1# 发表于 2012-05-09 08:40:21
In embedded systems, designers can reduce component count and increase flexibility by using a microprocessor to configure an FPGA. C code illustrates the use of either Slave Serial or SelectMAP mode. CPLD design files illustrate a synchronous interface between processor and FPGA.
xapp502.pdf
关键词:Using    Microprocessor    Conf
Rancho。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
