版主: 51FPGA
分享到:
共1条 1/1 1
采用数字控制输入阻抗:信号完整性与功耗的考虑的对比
    [您是本帖的第1141位阅读者]
Rancho
我是GG
高级会员
最后登陆时间:2015-01-14 09:17:39
直达楼层
1# 发表于 2012-05-07 18:52:51
On-die termination (ODT) promises higher signaling rates for printed circuit board (PCB) inter-chip interfaces through improved signal integrity. However, when using ODT, there is sometimes an associated power penalty. This application note explains the reason for the power penalty and suggests a simulation technique for comparing the signal integrity and power dissipation of internally and externally terminated versions of an interface.
xapp863.pdf
关键词:采用    数字    控制    输入    阻抗    信号    完整性    功耗
Rancho。
此贴由Rancho于2012-05-08 20:05:48最后编辑
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
