版主: 51FPGA
分享到:
共4条 1/1 1
Spartan 3E开发板上的ADC程序专帖
    [您是本帖的第5353位阅读者]
Jason_Zhang
我是GG
高级会员
最后登陆时间:2015-01-20 09:30:43
直达楼层
1# 发表于 2011-04-13 17:08:17
应网友“只为吸引你”的要求,我帮他写了个Spartan 3E开发板上的ADC的程序,包括程控放大器LTC6912和DAC LTC1407A的接口程序,只做了仿真,还没在板子上跑,请 只为吸引你 和其他感兴趣的网友在板子上调试看看,有什么问题或结果,欢迎反馈。
LTC6912时序
 LTC1407A
仿真结果
仿真软件为Modelsim 6.5c
接口程序
`timescale 1ns / 1ps
module LTC_ADC( Clk, Rst,
    AMP_nCS, AMP_SHDN, SPI_MOSI,
    SPI_SCK,
    AD_CONV, SPI_MISO
input Clk, Rst;
output wire AMP_SHDN;
output reg AMP_nCS, SPI_MOSI;
output reg SPI_SCK;
output reg AD_CONV;
input SPI_MISO;
assign AMP_SHDN = 1'b0;
parameter AMP_GAIN = 8'h11;
parameter STA_IDLE = 3'b001;
parameter STA_AMP = 3'b010;
parameter STA_ADC = 3'b100;
reg [2:0] Cur_State, Nxt_State;
reg [6:0] Cnter;
reg [13:0] Reg_ADC_CH1, Reg_ADC_CH2;
reg [7:0] Reg_AMP_Gain;
always @( posedge Clk )
begin
 if( Rst )
  Cur_State <= STA_IDLE;
 else
  Cur_State <= Nxt_State;
end
always @( Cur_State or Cnter )
begin
 case( Cur_State )
 STA_IDLE :
  begin
   if( Cnter == 7'd2 )
    Nxt_State = STA_AMP;
   else
    Nxt_State = STA_IDLE;
  end
 STA_AMP  :
  begin
   if( Cnter == 7'd16 )
    Nxt_State = STA_ADC;
   else
  end
 STA_ADC  :
  begin
  end
 default  :
  begin
   Cur_State = STA_IDLE;
  end
 endcase
end
begin
 if( Rst )
 begin
  AMP_nCS <= 1'b1;
  SPI_MOSI <= 1'b0;
  SPI_SCK <= 1'b1;
  AD_CONV <= 1'b0;
  Reg_AMP_Gain <= 14'h0000;
  Reg_ADC_CH1 <= 14'h0000;
  Reg_ADC_CH2 <= 8'h00;
  Cnter <= 7'h00;
 end
 else
 begin
  case( Cur_State )
  STA_IDLE :
   begin
    if( Cnter < 7'd2 )
    begin
     AMP_nCS <= 1'b1;
     SPI_MOSI <= 1'b0;
     SPI_SCK <= 1'b1;
     AD_CONV <= 1'b0;
     Reg_AMP_Gain <= AMP_GAIN;
     Cnter <= Cnter + 1'b1;
    end
    else
    begin
     AMP_nCS <= 1'b0;
     SPI_MOSI <= 1'b0;
     SPI_SCK <= 1'b1;
     AD_CONV <= 1'b0;
     Cnter <= 7'h00;
    end
   end
  STA_AMP  :
   begin
    AMP_nCS <= 1'b0;
    if( Cnter < 7'd16 )
    begin
     if( Cnter[0] == 1'b0 )
     begin
      SPI_SCK <= 1'b0;
      SPI_MOSI <= Reg_AMP_Gain[7];
      Reg_AMP_Gain <= { Reg_AMP_Gain[6:0], 1'b0 };
     end
     else
     begin
      SPI_SCK <= 1'b1;
     end
    end
    else
    begin
     Cnter <= 7'd0;
     SPI_SCK <= 1'b1;
     AMP_nCS <= 1'b1;
     AD_CONV <= 1'b0;
    end
   end
  STA_ADC  :
   begin
    if( Cnter==7'd0 )
    begin
     SPI_SCK <= 1'b0;
     AD_CONV <= 1'b1;
    end
    else if( Cnter==7'd1 )
    begin
     SPI_SCK <= 1'b1;
    end
    else if( Cnter <7'd6 )
    begin
     AD_CONV <= 1'b0;
      SPI_SCK <= 1'b0;
     else
      SPI_SCK <= 1'b1;
    end
    else if( Cnter <7'd34 )
    begin
      SPI_SCK <= 1'b0;
     else
     begin
      SPI_SCK <= 1'b1;
      Reg_ADC_CH1 <= { Reg_ADC_CH1[12:0], SPI_MISO };
     end
    end
    else if( Cnter <7'd38 )
    begin
      SPI_SCK <= 1'b0;
     else
     begin
      SPI_SCK <= 1'b1;
     end
    end
    else if( Cnter <7'd66 )
    begin
      SPI_SCK <= 1'b0;
     else
     begin
      SPI_SCK <= 1'b1;
      Reg_ADC_CH2 <= { Reg_ADC_CH2[12:0], SPI_MISO };
     end
    end
    else if( Cnter <7'd68 )
    begin
      SPI_SCK <= 1'b0;
     else
      SPI_SCK <= 1'b1;
    end
    else
    begin
     Cnter <= 7'd0;
    end
   end
  default  :
   begin
    AMP_nCS <= 1'b1;
    SPI_MOSI <= 1'b0;
    SPI_SCK <= 1'b1;
    AD_CONV <= 1'b0;
    Cnter <= 7'h00;
   end
  endcase
 end
end
// -------------------------- For Simulation ---------------------------------------
initial
begin
 Nxt_State = 3'b001;
end
endmodule
Testbench程序--------------------------------------------------------------------------------------------------------
// Company:
// Engineer:
// Create Date:    19:53:26 04/01/2011
// Design Name:
// Module Name:
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module tb_LTC_ADC;
//module tb_ltc_adc;
reg Clk;
reg Rst;
wire AMP_nCS, AMP_SHDN, SPI_MOSI, SPI_SCK, AD_CONV;
reg SPI_MISO;
LTC_ADC  uut(
 .Clk( Clk ),
 .Rst( Rst ),
 .AMP_nCS( AMP_nCS ),
 .AMP_SHDN( AMP_SHDN ),
 .SPI_MOSI( SPI_MOSI ),
 .SPI_SCK( SPI_SCK ),
 .AD_CONV( AD_CONV ),
 .SPI_MISO( SPI_MISO )
always #250 Clk = ~Clk;
initial
begin
// Initialize Inputs
 Clk = 0;
 Rst = 0;
 SPI_MISO = 0;
 #2000;
 Rst = 1;
 #2000;
 Rst = 0;
 #2000;
 while(1)
 begin
  @( negedge SPI_SCK )
   SPI_MISO = 1;
   SPI_MISO = 0;
   SPI_MISO = 0;
 end
end
endmodule
do文件为
# Create work library
vlib work
# Compile sources
vlog  "tb_LTC_ADC.v"
vlog  "LTC_ADC.v"
#vsim -voptargs="+acc" -t 1ps -lib work.tb_LTC_ADC glbl
vsim -t 1ps -novopt work.tb_LTC_ADC
#add wave /tb_LTC_ADC/*
#add wave /tb_LTC_ADC/uut/*
do {wave.do}
# Set the window types
view wave
view structure
view signals
# Source the user do file
# Run simulation for this time
run 100us
# End
贴出来的程序我就不排版了,详细的Modelsim工程我已经上传了,可以下载
——回复可见内容——
解压后,用Modelsim打开工程,输入 do run.do 就可以了。
PS.  只为吸引你的程序逻辑上有些乱,我就不帮你检查了,不好意思了。你就参考我的吧。
另外,希望大家以后有什么问题,还是在论坛上大家一起讨论吧,一般不接受站内PM、Email、QQ等提出的问题。
关键词:Spartan    开发    程序    专帖    State    Cn
My Email : zldpublic@gmail.com。
此贴由Jason_Zhang于2011-04-13 22:39:13最后编辑
RE: Spartan 3E开发板上的ADC程序专帖
Jason_Zhang
我是GG
高级会员
2# 发表于 2011-04-13 22:45:25
只为吸引你的原帖
呃,我的逻辑有些乱·········
你把“程序”两个字漏了,呵呵。
其实主要是我嫌麻烦,所以就自己写了一个。要知道,有些时候读程序比写程序还麻烦。
我觉得状态机不需要分得你那么细。把AMP和ADC的配置作为大状态,再用一个计数器做小状态就可以了,而且时序图总也表明了数字,所以用计数器是比较方便的。
我的程序中,复位之后,先配置AMP,然后就一直读取ADC了。
你先运行一下仿真文件,看看时序是不是你需要的。有问题再讨论
当然了,我也没写注释,所以也不好看。还是根据仿真时序来分析比较容易些
Jason_Zhang
我是GG
高级会员
3# 发表于 2011-04-14 10:15:13
只为吸引你的原帖
呃,我的逻辑有些乱·········
Jason_Zhang的原帖
你把“程序”两个字漏了,呵呵。
只为吸引你的原帖
昨天晚上看了,也仿真了,总的来看挺清楚的,就是sck那看得我那叫一个乱,呵呵。今天烧板子试一试,谢谢了。
嗯。外围的你自己封装一下,然后下载看看吧。我现在有事要出去,今晚才能再上网
Jason_Zhang
我是GG
高级会员
4# 发表于 2011-04-15 21:22:13
只为吸引你的原帖
我烧了你的程序,频率太高,有20几M。那个amp最大就能到10M。我给加了个分频。分到了8.+M。烧上还是不行,amp 放大输出,总是一个高电平。可能是那个放大的增益时序那,没弄好。觉得那个sck太繁琐了。我就还是改的我的那个程序。当然也是很繁琐,不过好在现在看见曙光了。呵呵
是否正确,用示波器或逻辑分析仪捕获一下不就知道时序是什么样的了嘛
共4条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
