版主: 51FPGA
分享到:
共3条 1/1 1
ISE问题
    [您是本帖的第6338位阅读者]
Garfield0525
我是GG
高级会员
最后登陆时间:2010-05-20 20:19:47
直达楼层
1# 发表于 2010-03-03 17:11:13
在一个工程综合后,进行Translate时遇到了下面的问题:
Reading NGO file "E:/examples1/myddc/ddc.ngc" ...
Loading design module "E:\examples1\myddc/bram_sram_ip.ngc"...
ERROR:NgdBuild:76 - File "E:\examples1\myddc/bram_sram_ip.ngc" cannot be merged
   into block "uut1" (TYPE="bram_sram_ip") because one or more pins on the
   block, including pin "wea", were not found in the file.  Please make sure
   that all pins on the instantiated component match pins in the lower-level
   design block (irrespective of case).  If there are bussed pins on this block,
   make sure that the upper-level and lower-level netlists use the same
   bus-naming convention.
Loading design module "E:\examples1\myddc/ddram_config_EMIFA.ngc"...
ERROR:NgdBuild:76 - File "E:\examples1\myddc/ddram_config_EMIFA.ngc" cannot be
   merged into block "uut5" (TYPE="ddram_config_EMIFA") because one or more pins
   on the block, including pin "wea", were not found in the file.  Please make
   sure that all pins on the instantiated component match pins in the
   lower-level design block (irrespective of case).  If there are bussed pins on
   this block, make sure that the upper-level and lower-level netlists use the
   same bus-naming convention.
Loading design module "E:\examples1\myddc/DDRAM4k_EMIFB.ngc"...
ERROR:NgdBuild:76 - File "E:\examples1\myddc/DDRAM4k_EMIFB.ngc" cannot be merged
   into block "test_EMIFB_Top_inst/uut4" (TYPE="DDRAM4k_EMIFB") because one or
   more pins on the block, including pin "wea", were not found in the file.
   Please make sure that all pins on the instantiated component match pins in
   the lower-level design block (irrespective of case).  If there are bussed
   pins on this block, make sure that the upper-level and lower-level netlists
   use the same bus-naming convention.
   into block "test_EMIFB_Top_inst/uut3" (TYPE="DDRAM4k_EMIFB") because one or
Loading design module "E:\examples1\myddc/DDRAM2_EMIFB.ngc"...
ERROR:NgdBuild:76 - File "E:\examples1\myddc/DDRAM2_EMIFB.ngc" cannot be merged
   into block "test_EMIFB_Top_inst/uut2" (TYPE="DDRAM2_EMIFB") because one or
Loading design module "E:\examples1\myddc/filter_ip.ngc"...
ERROR:NgdBuild:76 - File "E:\examples1\myddc/filter_ip.ngc" cannot be merged
   into block "F_M_l_Fi_inst/fil_3Q" (TYPE="filter_ip") because one or more pins
   on the block, including pin "dout<38>", were not found in the file.  Please
   make sure that all pins on the instantiated component match pins in the
   into block "F_M_l_Fi_inst/fil_3I" (TYPE="filter_ip") because one or more pins
   into block "F_M_l_Fi_inst/fil_1Q" (TYPE="filter_ip") because one or more pins
   into block "F_M_l_Fi_inst/fil_1I" (TYPE="filter_ip") because one or more pins
Loading design module "E:\examples1\myddc/mul_ip.ngc"...
Loading design module "E:\examples1\myddc/fifo_ip.ngc"...
Gathering constraint information from source properties...
Done.
Resolving constraint associations...
Checking Constraint Associations...
Done...
Checking Partitions ...
Checking expanded design ...
ERROR:NgdBuild:604 - logical block 'uut1' with type 'bram_sram_ip' could not be
   resolved. A pin name misspelling can cause this, a missing edif or ngc file,
   or the misspelling of a type name. Symbol 'bram_sram_ip' is not supported in
   target 'spartan3adsp'.
ERROR:NgdBuild:604 - logical block 'uut5' with type 'ddram_config_EMIFA' could
   not be resolved. A pin name misspelling can cause this, a missing edif or ngc
   file, or the misspelling of a type name. Symbol 'ddram_config_EMIFA' is not
   supported in target 'spartan3adsp'.
ERROR:NgdBuild:604 - logical block 'test_EMIFB_Top_inst/uut4' with type
   'DDRAM4k_EMIFB' could not be resolved. A pin name misspelling can cause this,
   a missing edif or ngc file, or the misspelling of a type name. Symbol
   'DDRAM4k_EMIFB' is not supported in target 'spartan3adsp'.
ERROR:NgdBuild:604 - logical block 'test_EMIFB_Top_inst/uut3' with type
ERROR:NgdBuild:604 - logical block 'test_EMIFB_Top_inst/uut2' with type
   'DDRAM2_EMIFB' could not be resolved. A pin name misspelling can cause this,
   'DDRAM2_EMIFB' is not supported in target 'spartan3adsp'.
ERROR:NgdBuild:604 - logical block 'F_M_l_Fi_inst/fil_3Q' with type 'filter_ip'
   could not be resolved. A pin name misspelling can cause this, a missing edif
   or ngc file, or the misspelling of a type name. Symbol 'filter_ip' is not
ERROR:NgdBuild:604 - logical block 'F_M_l_Fi_inst/fil_3I' with type 'filter_ip'
ERROR:NgdBuild:604 - logical block 'F_M_l_Fi_inst/fil_1Q' with type 'filter_ip'
ERROR:NgdBuild:604 - logical block 'F_M_l_Fi_inst/fil_1I' with type 'filter_ip'
Partition Implementation Status
  No Partitions were found in this design.
哪位大哥也遇到过同样的问题,帮忙解决一下,不胜感激.......................
关键词:问题    examples1    myddc    design
RE: ISE问题
Garfield0525
我是GG
高级会员
2# 发表于 2010-03-03 20:54:53
哪位帮帮忙啊..................谢谢了啊
RE: ISE问题
Garfield0525
我是GG
高级会员
3# 发表于 2010-03-10 14:59:04
问题已经解决,谢谢了.............
共3条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
