版主: 51FPGA
分享到:
共2条 1/1 1
请教verilog中流水线的用途?
    [您是本帖的第2772位阅读者]
godjohsn
性别保密
高级会员
最后登陆时间:2017-09-23 10:09:52
直达楼层
1# 发表于 2017-09-26 23:23:08
看到很多资料里说“利用流水线的设计方法,可大大提高系统的工作速度。”
这是一个教材里很常用的例程:
(1)非流水线实现方式
module adder_8bits(din_1, clk, cin, dout, din_2, cout);
   input [7:0] din_1;
    input clk;
    input cin;
    output [7:0] dout;
    input [7:0] din_2;
    output cout;
    reg [7:0] dout;
    reg       cout;
    always @(posedge clk) begin
            {cout,dout} <= din_1 + din_2 + cin;
    endendmodule
(2)2级流水线实现方式:
module adder_4bits_2steps(cin_a, cin_b, cin, clk, cout, sum);
    input [7:0] cin_a;
    input [7:0] cin_b;
    input cin;
    input clk;
    output cout;
    output [7:0] sum;
    reg cout;
    reg cout_temp;
    reg [7:0] sum;
    reg [3:0] sum_temp;
            {cout_temp,sum_temp} = cin_a[3:0] + cin_b[3:0] + cin;
    end
            {cout,sum} = {{1'b0,cin_a[7:4]} + {1'b0,cin_b[7:4]} + cout_temp, sum_temp};
    end
endmodule
注意:这里在always块内只能用阻塞赋值方式,否则会出现逻辑上的错误!
(3)4级流水线实现方式:
module adder_8bits_4steps(cin_a, cin_b, c_in, clk, c_out, sum_out);
    input [7:0] cin_a;
    input [7:0] cin_b;
    input c_in;
    input clk;
    output c_out;
    output [7:0] sum_out;
    reg c_out;
    reg c_out_t1, c_out_t2, c_out_t3;
    reg [7:0] sum_out;
    reg [1:0] sum_out_t1;
    reg [3:0] sum_out_t2;
    reg [5:0] sum_out_t3;
             {c_out_t1, sum_out_t1} = {1'b0, cin_a[1:0]} + {1'b0, cin_b[1:0]} + c_in;
    end
             {c_out_t2, sum_out_t2} = {{1'b0, cin_a[3:2]} + {1'b0, cin_b[3:2]} + c_out_t1, sum_out_t1};
    end
            {c_out_t3, sum_out_t3} = {{1'b0, cin_a[5:4]} + {1'b0, cin_b[5:4]} + c_out_t2, sum_out_t2};
    end
           {c_out, sum_out} = {{1'b0, cin_a[7:6]} + {1'b0, cin_b[7:6]} + c_out_t3, sum_out_t3};
    end
endmodule
可是在ISE12.3 下实际时序分析的结果:采用4级流水线比不采用流水线的延时更大:
非流水线方式: Timing constraint: TS_clk = PERIOD TIMEGRP "clk" 10 ns HIGH 50%;   0 paths analyzed, 0 endpoints analyzed, 0 failing endpoints   0 timing errors detected. (0 component switching limit errors)   Minimum period is   1.366ns.
4级流水线方式: Timing constraint: TS_clk = PERIOD TIMEGRP "clk" 10 ns HIGH 50%;   10 paths analyzed, 10 endpoints analyzed, 0 failing endpoints   0 timing errors detected. (0 setup errors, 0 hold errors, 0 component switching limit errors)   Minimum period is   3.422ns.
采用流水线之后延时更大,意味着系统最高频率更小,工作速度反而降低了,那流水线技术的意义究竟何在?
此帖由godjohsn于2017-09-26 23:25:57最后编辑
RE: 请教verilog中流水线的用途?
godjohsn
性别保密
高级会员
2# 发表于 2017-09-30 17:30:27
pexufe的原帖
FPGA内部结构本身就支持直接非流水线的模式,系统会对这种模式进行优化,增加了流水级数反而导致无法映射和优化
不好意思,进一步请教一下:
为什么分了流水无法优化?
那自己写程序的时候应怎么做,到底该不该细分流水?
共2条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
