版主: 51FPGA
分享到:
共1条 1/1 1
求助:K7的JTAG接口下载程序报CRC错误。
    [您是本帖的第12562位阅读者]
wangming169
我是GG
高级会员
最后登陆时间:2016-02-03 11:42:16
直达楼层
1# 发表于 2016-02-03 11:46:33
我将K7的bank0,14,15 的电源调整为3.3V,jtag可以扫描到芯片,下载程序到99%后就会出现下载失败,同时消息报CRC error:
PROGRESS_START - Starting Operation.
Maximum TCK operating frequency for this device chain: 66000000.
Validating chain...
Boundary-scan chain validated successfully.
1: Device Temperature: Current Reading:   46.44 C, Min. Reading:   43.98 C, Max. Reading:   47.42 C
1: VCCINT Supply: Current Reading:   1.037 V, Min. Reading:   1.031 V, Max. Reading:   1.040 V
1: VCCAUX Supply: Current Reading:   1.887 V, Min. Reading:   1.878 V, Max. Reading:   1.896 V
'1': Programming device...
'1': CRC error detected.
'1': Configuration data download to FPGA was not successful. Error detected in boot history register, please check your configuration setup and mode settings.
done.
INFO:Cse - Error shows in the status register, CRC Error bit is NOT 0.
INFO:Cse - Error shows in the status register, release done bit is NOT 1.
INFO:Cse - Status register values:
INFO:Cse - 1011 0000 0101 0000 0000 0000 0100 1010
PROGRESS_END - End Operation.
Elapsed time =     25 sec.
 Match_cycle = NoWait.
Match cycle: NoWait
 LCK_cycle = NoWait.
LCK cycle: NoWait
INFO:iMPACT - '1': Checking done pin....done.
'1': Programming terminated. DONE did not go high.
INFO:iMPACT - Using CseAdapterBSDevice
op.bit' ...
 not exist.
 not exist.
 not exist.
 not exist.
 not exist.
///////扫描寄存器的值是:
1': Reading bootsts register contents...
[0] VALID_0 - ERROR OR END OF STARTUP (EOS) DETECTED                       :         1
[1] FALLBACK_0 - FALLBACK TRIGGERED RECONFIGURATION                        :         0
[2] IPROG_0 - INTERNAL WARMBOOT (IPROG) TRIGGERED RECONFIGURATION          :         0
[3] WTO_ERROR_0 - WATCHDOG TIME OUT ERROR                                  :         0
[4] ID_ERROR_0 - FPGA DEVICE IDCODE ERROR                                  :         0
[5] CRC_ERROR_0 - CYCLIC REDUNDANCY CHECK (CRC) ERROR                      :         1
[6] WRAP_ERROR_0 - BPI FLASH ADDRESS COUNTER WRAP AROUND ERROR             :         0
[7] HMAC_ERROR_0 - HMAC ERROR                                              :         0
[8] VALID_1 - ERROR OR END OF STARTUP (EOS) DETECTED                       :         0
[9] FALLBACK_1 - FALLBACK TRIGGERED RECONFIGURATION                        :         0
[10] IPROG_1 - INTERNAL WARMBOOT (IPROG) TRIGGERED RECONFIGURATION         :         0
[11] WTO_ERROR_1 - WATCHDOG TIME OUT ERROR                                 :         0
[12] ID_ERROR_1 - FPGA DEVICE IDCODE ERROR                                 :         0
[13] CRC_ERROR_1 - CYCLIC REDUNDANCY CHECK (CRC) ERROR                     :         0
[14] WRAP_ERROR_1 - BPI FLASH ADDRESS COUNTER WRAP AROUND ERROR            :         0
[15] HMAC_ERROR_1 - HMAC ERROR                                             :         0
'1': Reading status register contents...
[0] CRC ERROR                                                              :         1
[1] DECRYPTOR ENABLE                                                       :         0
[2] PLL LOCK STATUS                                                        :         1
[3] DCI MATCH STATUS                                                       :         1
[4] END OF STARTUP (EOS) STATUS                                            :         0
[5] GTS_CFG_B STATUS                                                       :         0
[6] GWE STATUS                                                             :         0
[7] GHIGH STATUS                                                           :         0
[8] MODE PIN M[0]                                                          :         0
[9] MODE PIN M[1]                                                          :         1
[10] MODE PIN M[2]                                                         :         0
[11] INIT_B INTERNAL SIGNAL STATUS                                         :         1
[12] INIT_B PIN                                                            :         0
[13] DONE INTERNAL SIGNAL STATUS                                           :         0
[14] DONE PIN                                                              :         0
[15] IDCODE ERROR                                                          :         0
[16] SECURITY ERROR                                                        :         0
[17] SYSTEM MONITOR OVER-TEMP ALARM STATUS                                 :         0
[18] CFG STARTUP STATE MACHINE PHASE                                       :         0
[19] CFG STARTUP STATE MACHINE PHASE                                       :         0
[20] CFG STARTUP STATE MACHINE PHASE                                       :         0
[21] RESERVED                                                              :         0
[22] RESERVED                                                              :         0
[23] RESERVED                                                              :         0
[24] RESERVED                                                              :         0
[25] CFG BUS WIDTH DETECTION                                               :         1
[26] CFG BUS WIDTH DETECTION                                               :         0
[27] HMAC ERROR                                                            :         0
[28] PUDC_B PIN                                                            :         1
[29] BAD PACKET ERROR                                                      :         0
[30] CFGBVS PIN                                                            :         1
[31] RESERVED                                                              :         0
请问有大神知道什么原因吗?
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
