版主: 51FPGA
分享到:
共1条 1/1 1
Spartan 6 Jtag下载出问题
    [您是本帖的第1484位阅读者]
himalaya0604
我是MM
高级会员
最后登陆时间:2015-01-13 22:04:08
直达楼层
1# 发表于 2015-07-26 23:42:11
我做了50套板子,其中有20套板子下载都正常,但是也有大部分用impact下载失败,提示如下。
INFO:iMPACT - Current time: 2015/2/4 11:30:48
PROGRESS_START - Starting Operation.
INFO:iMPACT:583 - '1': The idcode read from the device does not match the idcode in the bsdl File.
INFO:iMPACT:1578 - '1': Device IDCODE : 00000100000001100100000010010011
INFO:iMPACT:1579 - '1': Expected IDCODE: 00000100000000000100000010010011
PROGRESS_END - End Operation.
Elapsed time = 0 sec.
如果我用initialize chain则是检测在位置设备:
Attempting to identify devices in the boundary-scan chain configuration...
INFO:iMPACT - Current time: 2015/2/4 11:33:28
Identifying chain contents...INFO:iMPACT:1588 - '0':The part does not appear to be Xilinx Part.
'0': : Manufacturer's ID =Unknown , Version : 2
INFO:iMPACT:501 - '1': Added Device UNKNOWN successfully.
done.
请各位大神们指点下,帮组下小弟。
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
