版主: 51FPGA
分享到:
共2条 1/1 1
SDK PS initialization failed
    [您是本帖的第2259位阅读者]
toeflsieasy
我是MM
高级会员
最后登陆时间:2015-01-13 22:10:25
直达楼层
1# 发表于 2015-07-13 23:13:04
新设计的Zynq,JTAG扫描没有问题,PL可以下载;进行SDK运行时出现Running PS initialization后time out。log如下:
已检查时钟(50MHz),电源,复位,上下拉,但一直找不到问题所在。各位是否有过类似问题?烦请帮忙查看。
谢谢!
16:19:48 INFO  : Processing command line option -hwspec E:/working/HT2635_FPGA_test/Vivado/HT2635_zynq_led/HT2635_zynq_led.sdk/SDK/SDK_Export/hw/design_1.xml.
16:21:56 INFO  : Processor reset is completed for ps7_cortexa9_1
16:21:56 INFO  : PS initialization will be done as it is not done before.
16:21:56 INFO  : Running PS initialization....
16:22:56 INFO  : Time out for XMD transaction is 60000
If you want to increase the timeout value, goto Windows-> Preferences -> Xilinx SDK -> XMD Startup
16:22:56 ERROR : Timeout occured while waiting to get reply for command "ps7_init"
16:22:56 ERROR : Unexpected error while launching program. java.lang.RuntimeException: Error while running ps7_init method.
       at com.xilinx.sdk.targetmanager.internal.TM.run_ps7_init(Unknown Source)
       at com.xilinx.sdk.targetmanager.internal.TM.runPs7Init(Unknown Source)
RE: SDK PS initialization failed
toeflsieasy
我是MM
高级会员
2# 发表于 2015-07-13 23:15:07
看不懂
共2条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
