版主: 51FPGA
分享到:
共1条 1/1 1
求助,spartan-6 JTAG下不进去程序
    [您是本帖的第2151位阅读者]
xilinx论坛
我是MM
高级会员
最后登陆时间:2015-03-19 10:58:07
直达楼层
1# 发表于 2015-07-10 22:12:52
新作了一块板子,JTAG直接 下载 程序失败, 但 IMPACT 可以识别FPGA,用示波器观察TDO,不下程序时为高电平,下载时一直为低电平,导致 INFO:iMPACT - 0000 0000 0000 0000 ,不知是什么原因,请大家帮个忙,谢谢。PS:板子采用主串模式,原理图有点问题,现在先只考虑JTAG直接下载程序。 原理图见附件。
IMPACT信息如下:
PROGRESS_END - End Operation.
Elapsed time = 0 sec.
Type = 0x0004.
ESN device is not available for this cable.
Attempting to identify devices in the boundary-scan chain configuration...
INFO:iMPACT - Current time: 2014/10/15 10:43:48
PROGRESS_START - Starting Operation.
Identifying chain contents...'0': : Manufacturer's ID = Xilinx xc6slx16, Version : 4
INFO:iMPACT:1777 -
Reading D:/Xilinx/14.4/ISE_DS/ISE/spartan6/data/xc6slx16.bsd...
INFO:iMPACT:501 - '1': Added Device xc6slx16 successfully.
done.
Elapsed time = 1 sec.
'1': Loading file 'E:/FPGAchengxu/FPGA_DSP1.0/top.bit' ...
done.
INFO:iMPACT:2257 - Startup Clock has been changed to 'JtagClk' in the bitstream stored in memory,
but the original bitstream file remains unchanged.
UserID read from the bitstream file = 0xFFFFFFFF.
Data width read from the bitstream file = 1.
INFO:iMPACT - Current time: 2014/10/15 10:44:10
Maximum TCK operating frequency for this device chain: 25000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': Programming device...
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'1': Reading status register contents...
[0] CRC ERROR : 0
[1] IDCODE ERROR : 0
[2] DCM LOCK STATUS : 0
[3] GTS_CFG_B STATUS : 0
[4] GWE STATUS : 0
[5] GHIGH STATUS : 0
[6] DECRYPTION ERROR : 0
[7] DECRYPTOR ENABLE : 0
[8] HSWAPEN PIN : 0
[9] MODE PIN M[0] : 0
[10] MODE PIN M[1] : 0
[11] RESERVED : 0
[12] INIT_B PIN : 0
[13] DONE PIN : 0
[14] SUSPEND STATUS : 0
[15] FALLBACK STATUS : 0
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT:579 - '1': Completed downloading bit file to device.
INFO:iMPACT:188 - '1': Programming completed successfully.
LCK_cycle = NoWait.
LCK cycle: NoWait
INFO:iMPACT - '1': Checking done pin....done.
'1': Programming terminated. DONE did not go high.
FPGA EXP Card_F.pdf
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
