版主: 51FPGA
分享到:
共1条 1/1 1
zynq从SD卡启动Linux失败
    [您是本帖的第1013位阅读者]
zxzzy2009
我是MM
高级会员
最后登陆时间:2015-01-27 12:19:17
直达楼层
1# 发表于 2015-04-07 21:20:24
我们自己定制了一个zynq-7000板,当从SD卡启动Linux的时候,出现Uncompressing Linux...信息后,就一直挂起了,是什么原因造成的呢
U-Boot 2012.04.01-svn35 (Oct 17 2014 - 07:56:55)
DRAM: 512 MiB
WARNING: Caches not enabled
MMC: SDHCI: 0
Using default environment
In: serial
Out: serial
Err: serial
Net: zynq_gem
Hit any key to stop autoboot: 5  4 3  2 1 0
Copying Linux from SD to RAM...
Device: SDHCI
Manufacturer ID: 3
OEM: 5344
Tran Speed: 25000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
reading zImage MMC: Error reading sector 33280 (0x00008200)
Error reading cluster
** Unable to read "zImage" from mmc 0:1
** reading devicetree.dtb
7204 bytes read
reading ramdisk8M.image.gz
MMC: Error reading sector 22029 (0x0000560d)
** Unable to read "ramdisk8M.image.gz" from mmc 0:1
** ## Starting application at 0x00008000 ...
Uncompressing Linux...Uncompressing Linux...
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
