版主: 51FPGA
分享到:
共1条 1/1 1
Xilinx Virtex-7 FPGA VC707评估方案
    [您是本帖的第987位阅读者]
xilinx论坛
我是MM
高级会员
最后登陆时间:2015-03-19 10:58:07
直达楼层
1# 发表于 2015-04-04 14:24:57
gaochy1126 发表于 2012-7-20 18:16:39 Xilinx公司的7系列FPGA产品包括Artix™-7系列, Kintex™-7系列和Virtex®-7系列,具有低成本,小尺寸,高性价比和大容量以及超高端连接带宽,逻辑功能和信号处理能力等特性,适合要求最严格的高性能应用.本文介绍了Xilinx 7系列FPGA主要特性,7系列三种FPGA性能比较表,以及Virtex-7 FPGA主要特性, Virtex-7 FPGA评估板VC707主要特性, 方框图,电路图和材料清单. Xilinx® 7 series FPGAs comprise three new FPGA families that address the complete range of system requirements, ranging from low cost, small form factor, cost-sensitive, high-volume applications to ultra high-end connectivity bandwidth, logic capacity, and signal processing capability for the most demanding high-performance applications. The 7 series devices are the programmable silicon foundation for Targeted Design Platforms that enable designers to focus on innovation from the outset of their development cycle. The 7 series FPGAs include: • Artix™-7 Family: Optimized for lowest cost and power with small form-factor packaging for the highest volume applications. • Kintex™-7 Family: Optimized for best price-performance with a 2X improvement compared to previous generation, enabling a new class of FPGAs. • Virtex®-7 Family: Optimized for highest system performance and capacity with a 2X improvement in system performance. Highest capability devices enabled by stacked silicon interconnect (SSI) technology. Built on a state-of-the-art, high-performance, low-power (HPL), 28 nm, high-k metal gate (HKMG) process technology, 7 series FPGAs enable an unparalleled increase in system performance with 2.9 Tb/s of I/O bandwidth, 2 million logic cell capacity, and 5.3 TMAC/s DSP, while consuming 50% less power than previous generation devices to offer a fully programmable alternative to ASSPs and ASICs. All 7 series devices share a scalable, optimized fourth-generation Advanced Silicon Modular Block (ASMBL™) column-based architecture that reduces system development and deployment time with simplified design portability. Xilinx 7系列FPGA主要特性: • Advanced high-performance FPGA logic based on real 6-input lookup table (LUT) technology configurable as distributed memory. • 36 Kb dual-port block RAM with built-in FIFO logic for on-chip data buffering. • High-performance SelectIO™ technology with support for DDR3 interfaces up to 1,866 Mb/s. • High-speed serial connectivity with built-in multi-gigabit transceivers from 600 Mb/s to maximum rates of 6.6 Gb/s up to 28.05 Gb/s, offering a special low-power mode, optimized for chip-to-chip interfaces. • A user configurable analog interface (XADC), incorporating dual 12-bit 1MSPS analog-to-digital converters with on-chip thermal and supply sensors. • DSP slices with 25 x 18 multiplier, 48-bit accumulator, and pre-adder for high performance filtering, including optimized symmetric coefficient filtering. • Powerful clock management tiles (CMT), combining phase-locked loop (PLL) and mixed-mode clock manager (MMCM) blocks for high precision and low jitter. • Integrated block for PCI Express® (PCIe), for up to x8 Gen3 Endpoint and Root Port designs. • Wide variety of configuration options, including support for commodity memories, 256-bit AES encryption with HMAC/SHA-256 authentication, and built-in SEU detection and correction. • Low-cost, wire-bond, lidless flip-chip, and high signal integrity flipchip packaging offering easy migration between family members in the same package. All packages available in Pb-free and selected packages in Pb option. • Designed for high performance and lowest power with 28 nm, HKMG, HPL process, 1.0V core voltage process technology and 0.9V core voltage option for even lower power. VC707评估板电路图见:https://secure.xilinx.com/webreg/clickthrough.do?cid=181656&license=RefDesLicense&filename=vc707_Schematic_xtp135_rev1_0.pdfVC707评估板材料清单见: https://secure.xilinx.com/webreg/clickthrough.do?cid=181642&license=RefDesLicense&filename=vc707_BOM_rdf0154_rev1_0.zip 详情请见: http://www.xilinx.com/support/documentation/data_sheets/ds183_Virtex_7_Data_Sheet.pdf 和http://www.xilinx.com/support/documentation/boards_and_kits/ug885_VC707_Eval_Bd.pdf
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
