版主: 51FPGA
分享到:
共1条 1/1 1
内核和文件系统移植出现的问题(Kernel panic - not syncing)
    [您是本帖的第2644位阅读者]
piziwo
我是GG
高级会员
最后登陆时间:2015-01-21 23:52:49
直达楼层
1# 发表于 2014-10-10 22:12:26
[    0.850000] mmc0: new high speed SDHC card at address 1234
[    0.860000] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[    0.870000]  mmcblk0: p1 p2
[    1.740000] EXT4-fs (mmcblk0p2): recovery complete
[    1.760000] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.770000] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.770000] Freeing init memory: 148K
[    1.780000] Kernel panic - not syncing: No init found.  Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[    1.790000] CPU0: stopping
[    1.790000] [<c0012fa4>] (unwind_backtrace+0x0/0xe0) from [<c0011f7c>] (ipi_cpu_stop+0x3c/0x68)
[    1.790000] [<c0011f7c>] (ipi_cpu_stop+0x3c/0x68) from [<c00122fc>] (handle_IPI+0x68/0xb4)
[    1.790000] [<c00122fc>] (handle_IPI+0x68/0xb4) from [<c0008460>] (gic_handle_irq+0x54/0x5c)
[    1.790000] [<c0008460>] (gic_handle_irq+0x54/0x5c) from [<c000d340>] (__irq_svc+0x40/0x70)
出现这样的错误怎么解决呢?是内核配置出问题了吗?
关键词:Kernel panic - not syncin
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
