版主: 51FPGA
分享到:
共1条 1/1 1
Zynq-7000 All Programmable SoC (XC7Z030, XC7Z045, and XC7Z100): DC and AC Switch
    [您是本帖的第11754位阅读者]
wangying
我是MM
高级会员
最后登陆时间:2015-01-26 10:29:53
直达楼层
1# 发表于 2013-06-08 09:59:06
(英文文档,Xilinx公司2013年4月新鲜出炉)
Zynq.-7000 All Programmable SoCs are available in -3, -2, and -1 speed grades, with -3 having the highest performance. Zynq-7000 device DC and AC characteristics are specified in commercial, extended, and industrial temperature ranges. Except the operating temperature range or unless otherwise noted, all the DC and AC electrical parameters are the same for a particular speed grade (that is, the timing characteristics of a -1 speed grade industrial device are the same as for a -1 speed grade commercial device). However, only selected speed grades and/or devices are available in the commercial, extended, or industrial temperature ranges.——回复可见内容——
关键词:Zynq-7000    Programmable    XC
迎九。
此贴由wangyu于2013-06-08 10:09:57最后编辑
共1条 1/1 1
快速回复主题
  • 匿名不能发帖!请先 [ 登陆 注册 ]
